AnsweredAssumed Answered
PyScript, simple error help! Field Mapping Object
Question asked by clclark on Jan 10, 2013
Latest reply on Jan 11, 2013 by clclark
Okay. This first block of code will run with no error and work just fine.
import arcpy
... arcpy.env.workspace = "G:\ChrisGIS\WDFW_NWIFC_EVENT_17100101.gdb"
... arcpy.env.overwriteOutput = "True"
... #Variables
... workspace = "G:\ChrisGIS\WDFW_NWIFC_EVENT_17100101.gdb"
... inputFC = "WDFW_CHFA_2HEM_evt_1"
... targetFC = "WDFW_CHFA_2HEM_evt_olay_1"
... fm_permid = arcpy.FieldMap()
... fm_reach = arcpy.FieldMap()
... fms = arcpy.FieldMappings()
... fm_permid.addInputField(inputFC,"Permanent_Identifier")
... permid_name = fm_permid.outputField
... permid_name.name = "Permanent_ID"
... fm_permid.outputField = permid_name
... fm_reach.addInputField(inputFC,"ReachCode")
... reach_name = fm_reach.outputField
... reach_name.name = "ReachCode"
... fm_reach.outputField = reach_name
... fms.addFieldMap(fm_permid)
... fms.addFieldMap(fm_reach)
... # Process: Append
... arcpy.Append_management(workspace+"\\"+inputFC, workspace+"\\"+targetFC,"NO_TEST",fms)
I change the above code slightly, by adding another FieldMap which is strnm. But it generates an error. I made what I added in red so you can easily locate it. Here is that code
import arcpy
#Variables
fm_strnm = arcpy.FieldMap ()
fm_strnm.addInputField(inputFC,"STRM_NAME")
strnm_name = fm_strnm.outputField
strnm_name.name = "LLID_STRM_NAME"
strnm.outputField = strnm_name
fms.addFieldMap(fm_strnm)
# Process: Append
Runtime error <type 'exceptions.NameError'>: name 'strnm' is not defined
I do not understand this. I do not change anything, and pretty much copy the first block of code and simply try to add one more object. Any help would be great!! I am still very green to scripting and this is my first time messing with the FieldMappings Object.
Outcomes
