scottaidh
Assign Z value from DEM to line ends
Discussion created by scottaidh on Jan 9, 2013
Latest reply on Jan 10, 2013 by curtvprice
PLEASE HELP URGENT - Is there anyone at all who can help with this?  I wrote a script based on the Extract Value To Points tool but it doesn't work properly.
I have a simplified line shapefile and I want to add elevation (z values) from a DEM raster layer to the end points of the lines.
I have written the following code (its user input) but when I run it as a tool it reports that it has run successfully but it doesn't actually output the point shape file with the z values!
Any hints or even alternative suggestions would be appreciated.
code -
# script to extract raster values to point shapefile
# adapted by Scott MacDonald Kingston University k0848626 GSM655Programming Asssignment C
# import system modules
import arcpy
from arcpy import env
from arcpy.sa import *
# get user supplied path, layers and fields
path = arcpy.GetParameterAsText(0)
arcpy.env.workspace = path
# in Feature Layer is Confluence_Pts
in_point_features = arcpy.GetParameterAsText(1)
# in Raster Layer is DEM
in_raster = arcpy.GetParameterAsText(2)
# out Feature Class
out_point_features = arcpy.GetParameterAsText(3)
# error trapping measures
try:
# check out spatial analyst extension
# run the ExractValuesToPoints tool
arcpy.ExtractValuesToPoints(in_point_features, in_raster, out_point_features)
# check in spatial analyst extension
arcpy.CheckInExtension("Spatial")
except:
print arcpy.GetMessages()
Outcomes
