2 featureclass searches, first always works and second always fails
652
01-09-2013 05:40 AM
GaryBushek
New Contributor III
I'm getting some errors trying to do a search on a feature class.  The first search always works but the second search seems to fail 80% of the time and its typically a crash on line "pFC4 = streetSegFC2.Search(pSF4, True)".  Im assuming it crashes instead of being caught because of an "out of memory" error.  I'm realeasing the first cursor the best I can in every way i know how to but it seems to still be holding onto the cursor in memory. Originally I was using the same featureclass to search from but I decided to create a separate instance of the featureclass and that didn't help.  I tried creating a completely separate workspace to create the second featureclass from which triggered a completely separate SDE stream/connection but it still fails.  Any ideas on what to do if the cursors or memory aren't being fully released?  The 2 searches below are virtually identical and hitting the same database featureclass.
Thanks, Gary
            pSF = New SpatialFilterClass()
            pcomReleaser.ManageLifetime(pSF)
            pSF.Geometry = pTopo.Buffer(bufTol)
            pSF.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
            pSF.WhereClause = "FULLSTNAME='MAIN ST'"
            Try
                pFC = streetSegFC.Search(pSF, True)
                pcomReleaser.ManageLifetime(pFC)
                pF = pFC.NextFeature
                If pF Is Nothing Then
                    Log.Log(LogLevel.DetailedInfo, "No streets found", _logFileName)
                    Return Nothing
                End If
            Catch ex As Exception
                Log.Log(LogLevel.Exception, ex.Message & vbCrLf & ex.StackTrace, _logFileName)
            Finally
                pcomReleaser.dispose()
                Common.Release(pFC)
                pFC = Nothing
            End Try
Some code
            pSF4 = New SpatialFilterClass()
            pcomReleaser.ManageLifetime(pSF4)
            pSF4.Geometry = pTopo2.Buffer(bufTol)
            pSF4.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
            pSF4.WhereClause = "FULLSTNAME='MAIN ST'"
            Try
                pcomReleaser.ManageLifetime(pFC4)
                pF4 = pFC4.NextFeature
                If pF4 Is Nothing Then
                    Return Nothing
                End If
            Finally
                Common.Release(pFC4)
                pFC4 = Nothing
            End Try
JasonPike
Thanks, Gary
            Try
                    Return Nothing
                End If
            Finally
                Common.Release(pFC)
                pFC = Nothing
            End Try
Some code
            Try
                    Return Nothing
                End If
            Finally
                pFC4 = Nothing
            End Try
Try putting the result of pTopo.Buffer(bufTol) into a variable before assigning it to pSF4.Geometry and releasing it using Marshal.ReleaseComObject.
If you'll post an example that compiles, runs, and reproduces the problem, I'll be happy to go through it more thoroughly.
GaryBushek
New Contributor III
I'll give that a try.  We put a ticket in with ESRI and one suggestion we got was to retrieve the feature class from the map server object instead of the using IFeatureWorkspace.OpenFeatureClass().  We were hoping to get around changing the code too much because its a migration from 9.1 and a relatively large complex process.  thanks for the tip and i'll give an update as soon as I know either way.
Gary
JasonPike
Gary
Great! Also, here is something else you can use to help analyze the problem (use UMDH to show stacks that are hanging around in memory): http://forums.arcgis.com/threads/75186-Memory-leak-with-FeatureClass-object?p=263735#post263735
Good luck. I'm very interested to hear what you find out.
