License Manager Service won't start
9351
01-08-2013 01:52 PM
StevenGriffith
New Contributor III
I was having problems connecting with our license manager (multiple firewalls - fun) and tried to pin the port to a specific number, following the directions found on this site. However, once I finished editing the service.txt file, the license manager service would not restart. The debug listing is:
[INDENT]13:55:57 (lmgrd) Starting vendor daemon at port 27000
13:55:57 (lmgrd) Using vendor daemon port 27000 specified in license file
13:55:57 (lmgrd) REStarted ARCGIS (pid 5572)
13:55:57 (ARCGIS) FLEXnet Licensing version v11.10.0.0 build 95001 i86_n3
13:55:58 (ARCGIS) Server started on prvgis2 for: ACT
13:55:58 (ARCGIS) Viewer  Viewer
13:55:58 (ARCGIS) EXTERNAL FILTERS are OFF
13:55:58 (lmgrd) ARCGIS using TCP-port 0
13:55:58 (ARCGIS) tcp_s is bad!!! Exiting
13:55:58 (ARCGIS) EXITING DUE TO SIGNAL 28 Exit reason 5
13:56:03 (lmgrd) ARCGIS exited with status 28 (Communications error)[/INDENT]
This is a Windows Server 2008 R2 Standard, running in a VM instance. The server firewall is running, port 27000 (among others) is open and there is no other license manager on this server. Other services on this machine that use TCP/IP such as ArcGIS Server 10.1.1 are working just fine.
Any pointers or help is appreciated.
P.S. Turning off the server's firewall had no apparent effect ...
Steve G.
StevenGriffith
New Contributor III
If you notice the error text listed here, you'll see that the lmgrd process is starting on port 27000 *and* the vendor daemon (ARCGIS) is also starting on port 27000. I moved the vendor port to 27001 in the service.txt file and suddenly, all is good!
Steve G.
StevenGriffith
New Contributor III
Steve G.
ArshaYuditha_Amiranti
I also face the same issue with license manager 10.6
I have tried to move the vendor port from 27001 to 27000 and 27009, but still no luck. So I deauthorized the license and clear the trusted storage. And voila! It works!!
