Regarding Web page: http://resources.arcgis.com/en/help/soap/10.1/01vp/01vp00000096000000.htmI used this example. It works, however I noticed that it never gets to the code to set the minimum candidate score. The LocatorArray never has that property value. How do I change the minimum candidate score?
' Change locator property value
Dim index2 As Integer
For index2 = 0 To locatorArray.Length - 1 Step index2 + 1
Dim property2 As PropertySetProperty = locatorArray(index2)
Select Case property2.Key
Case "MinimumCandidateScore"
property2.Value = "80"
End Select
