I keep generating tokens here 'https://www.arcgis.com/sharing/generateToken?' without any problems. I then use the token to load Feature Services hosted from ArcGIS Online in my web app. The problem is that the tokens never seem to last the length I specify in the url, ie.expiration=1440.
It doesn't seem to matter what I put down, 365 days, 6 months or 10 days the token works only once it seems. Am I not understanding how tokens work? I thought that by setting the expiration to 1440 the token would be good for 10 days?
Interesting, but I don't get how I /use/ a token. I have one, and now need to access a layer via HTTPS.
Adding &token=crazylongstringwithlotsofcharacters to the URL doesn't seem to cut it, but I haven't found in the documentation where else to put it.
For instance, I believe that once I have a token, I should be able to to into an anonymous/incognito browser window and enter the layer URL I would like to fetch and supply the token somewhere to fetch it.
