Hello,I'm trying to create a loop that will allow me to intersect 50 files with each other.My first input is a polygon layer resulting from coverage analysis (Analysis Network Layer) containing all the fire stationMy second input is a layer polygon layer resulting coverage analysis (Analysis Network Layer) containing all the fire station - 1From the result of the intersection, I compare two columns together from a condition and remove the selection will be my input to the next intersection operation.Until there everything goes well, the problem is that I want to create a loop to automate the process. I find it difficult to figure out how to use a layer resulting and input at the sametime to do an intersection analysis.
import arcpy
from arcpy import env
env.overwriteOutput = True
env.workspace = "S:\Travail\Zone_Support_mutuel_test\Test_temp\ServiceAreaV2"
j = 1
outIntersectGlobal = "in_memory" + "\\" + "IntersectGlobal"
outIntersect = outputPolygons + "\\" + "Intersect"
IntersectResult = "in_memory" + "\\" + "Intersect" + j
fcGlobal = arcpy.ListFeatureClasses("Global*","Polygons")
fclist = arcpy.ListFeatureClasses("C*","Polygons")
print fcGlobal[0]
print fclist[1]
#for fc in arcpy.ListFeatureClasses("C*","Polygons"):
#print fcGlobal
#print fc.Nom
# Intersect Network analysis polygon( All fire Station coverage) with (All fire station minus 1)
arcpy.Intersect_analysis([fcGlobal,fclist[0]],"outIntersectGlobal")
codeblock = "def isSame(x, y):\n\n fieldA = str(x)\n\n fieldB = str(y)\n\n if fieldA == fieldB:\n\n return 1\n\n else:\n\n return 0\n"
isSameQuery = "isSame" = '1'
arcpy.AddField_management(outIntersectGlobal,"isSame","SHORT", "5", "", "", "", "NULLABLE", "NON_REQUIRED", "")
arcpy.CalculateField_management(outIntersectGlobal,"isSame","isSame( !Name!, !Name_1! )","Python_9.3",codeblock)
#arcpy.CopyFeatures_management(outIntersectGlobal, outputPolygons + "\\" + "Intersect")
arcpy.MakeFeatureLayer_management(outIntersectGlobal,"Intersect1",isSameQuery)
j+= 1
# Second intersection
arcpy.Intersect_analysis([outIntersectGlobal,fclist[1]],IntersectResult)
arcpy.AddField_management(IntersectResult,"isSame","SHORT", "5", "", "", "", "NULLABLE", "NON_REQUIRED", "")
arcpy.CalculateField_management(IntersectResult,"isSame","isSame( !Name!, !Name_1! )","Python_9.3",codeblock)
arcpy.MakeFeatureLayer_management(outIntersectGlobal,IntersectResult,isSameQuery)
j+= 1
### Blocked with the ouput of the intersect result and still incrementing it to have it as input for the next loop ###
for i in range(fclist):
print i
arcpy.Intersect_analysis(["IntersectResult","i"],
arcpy.MakeFeatureLayer_management(IntersectResult,"IntersectResult" + j,isSameQuery)
j+= 1
Thanks you for your help
