Below is my layout.js.I've added the identity manager and secured my feature service and I'm not getting prompted for creditials. The feature services doesn't show or draw. I'm at version 2.8. If I flip over to 3.2 none of my layers draw in I.E version 9.0.8112 but they do in Mozilla. Either way I don't see the login dialog for the sercured service.Am I missing something? Do I need to be at 3.2? Does I.E. 9.0.8112 support 3.2?THanksJ
dojo.require("esri.map");
dojo.require("esri.arcgis.utils");
dojo.require("esri.IdentityManager");
dojo.require("dijit.layout.TabContainer")
dojo.require("esri.dijit.editing.Editor-all");
dojo.require("esri.dijit.BasemapGallery");
dojo.require("dijit.Tooltip");
dojo.require("esri.dijit.Legend");
dojo.require("dijit.form.CheckBox");
dojo.require("esri.tasks.locator");
dojo.require("dojo.number");
dojo.require("dojox.grid.DataGrid"); //Find task - data table grid
dojo.require("dojo.data.ItemFileReadStore"); //Find Task
dojo.require("esri.tasks.find"); //find task
dojo.require("esri.tasks.query"); //query task
dojo.require("esri.SnappingManager");
var map;
var editorSettings;
var map;
var basemapGallery;
var bingKey = 'AiTi9z8-SSO1SqTeqHIhX2FOOe41v74qv_NIuw4JBnoyWwmybvT5uaFt8HSzIvgN';
var legendLayers = [];
//for layer list
var visible = [];
var Baselayers;
var mapLayers = []; //array of layers in client map - for feature layers to map
var locator;
var findTask; //Find Task
var findParams; //Find Task
var grid; //Find Task
var store; //Find Task
var queryTask; //Query Task
var query; //Query Task
function init() {
dojo.connect(grid, "onRowClick", onRowClickHandler); //FIND TASK
// dojo.connect(gridsup, "onRowClick", onRowClickHandler); //FIND TASK
//hide grid on startup
esri.hide(dojo.byId("grid")); //Grid for Signs
esri.hide(dojo.byId("gridsup")); //Grid for supports
//snapping is enabled for this sample - change the tooltip to reflect this
esri.bundle.toolbars.draw.start = esri.bundle.toolbars.draw.start + "<br/>Press <b>CTRL</b> to enable snapping";
esri.bundle.toolbars.draw.addPoint = esri.bundle.toolbars.draw.addPoint + "<br/>Press <b>CTRL</b> to enable snapping";
//This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
//replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
//for details on setting up a proxy page.
esri.config.defaults.io.proxyUrl = "/proxypage_net/proxy.ashx";
//This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
var extent = new esri.geometry.Extent({
"xmin": -13048964.9158736,
"ymin": 3906979.12225891,
"xmax": -13008585.9918137,
"ymax": 3922872.31483902,
"spatialReference": {
"wkid": 102100
map = new esri.Map("map", {
extent: extent,
logo:false
//Create Basemap Gallery
createBasemapGallery();
dojo.connect(map, "onLoad", function() {
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
dojo.connect(map, "onLayersAddResult", initEditing);
//Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://myserver/ArcGIS/rest/services/Imagery_102100/MapServer");
map.addLayer(basemap);
Baselayers = new esri.layers.ArcGISDynamicMapServiceLayer
("http://myserver/ArcGIS/rest/services/BaseLayers_102100/MapServer",{"opacity":0.5});
// legendLayers.push({layer:Baselayers,title:"Baselayers"});
map.addLayer(Baselayers);
legendLayers.push({layer:Baselayers,title:'Base Layers'});
//for layer list
if (Baselayers.loaded) {
buildLayerList(Baselayers);
else {
dojo.connect(Baselayers, "onLoad", buildLayerList);
//end code for layerlist
var editSigns = new esri.layers.FeatureLayer("http://myserver/ArcGIS/rest/services/Signs/FeatureServer/0", {
mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
outFields: ["*"]
mapLayers.push(editSigns);
var editSignSupports = new esri.layers.FeatureLayer("http://myserver/ArcGIS/rest/services/Signs/FeatureServer/1", {
outFields: ["*"]
mapLayers.push(editSignSupports);
legendLayers.push({layer:editSignSupports,title:'SignSupport'});
legendLayers.push({layer:editSigns,title:'Signs'});
//############################Add for out of the box legend ######################///
dojo.connect(map,'onLayersAddResult',function(results){
var legend = new esri.dijit.Legend({
map:map,
layerInfos:legendLayers
},"legendDiv");
legend.startup();
//############################end Add for out of the box legend ######################///
map.addLayers([editSignSupports, editSigns]);
// map.addLayers([operationsPointLayer, operationsPolygonLayer, operationsLineLayer]);
// dojo.byId("title") = test;//response.itemInfo.item.title;
// dojo.byId("dataSource") = <p> Test </>;
//locator = new esri.tasks.Locator("http://tasks.arcgis.com/ArcGIS/rest/services/WorldLocator/GeocodeServer");
locator = new esri.tasks.Locator("http://myserver/ArcGIS/rest/services/AddressLoc102100/GeocodeServer");
dojo.connect(locator, "onAddressToLocationsComplete", showResults);
// map.infoWindow.resize(200,125);
//************************FIND TASK for SIGNS *********************************************
//Create Find Task using the URL of the map service to search
findTask = new esri.tasks.FindTask("http://myserver/ArcGIS/rest/services/Signs/MapServer/");
// findTask = new esri.tasks.FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/");
//Create the find parameters
findParams = new esri.tasks.FindParameters();
findParams.returnGeometry = true;
findParams.layerIds = [0];
// findParams.searchFields = ["SIGNTYPE"];
// findParams.searchFields = ["OWNERNME1","OWNERNME2"];
findParams.searchFields = ["DATEINST","SIGNCATEGORY","SIGNTYPE","DIRFACES","SUBSTRMAT","BACKGRDMAT","SIGNSIZE","SIGNMEMO","HEIGHT","SUPPORTID"];
findParams.outSpatialReference = map.spatialReference;
//*****************************FIND TASK *******************************************************************************
//**************************Sign QUERY TASK ***************************************////
// build query
queryTask = new esri.tasks.QueryTask("http://myserver/ArcGIS/rest/services/Signs/MapServer/0");
//dojo.connect(queryTask, "onComplete", showResults);
//build query filter
query = new esri.tasks.Query();
query.returnGeometry = true;
// query.outFields = ["FACILITYID","DATEINST","SIGNCATEGORY","SIGNTYPE","DIRFACES","SUBSTRMAT","BACKGRDMAT","SIGNSIZE","SIGNMEMO","HEIGHT","SUPPORTID","OBJECTID"];
query.outFields = ["*"];
query.outSpatialReference = map.spatialReference;
//************************** END Sign QUERY TASK ***************************************////
//**************************Support QUERY TASK ***************************************////
// build query
queryTaskSupport = new esri.tasks.QueryTask("http://myserver/ArcGIS/rest/services/Signs/MapServer/1");
querySupport = new esri.tasks.Query();
querySupport.returnGeometry = true;
querySupport.outFields = ["*"];
querySupport.outSpatialReference = map.spatialReference;
