Installing Arcgis_js_jsapi 3.2 on apache/tomcat
1197
12-20-2012 10:21 AM
WilliamIde
I have installed apache2.2/tomcat 7 on my windows server 2003.  Apache is up.  tomcat is up.  Arcgis server 10.1 is up. I can connect to it from another machine with arcmap.
I followed the instructions for installing arcgis_js_jsapi.  However the instructions are only for IIS.  So what I did was load it into the webapps directory in tomcat.  Then I change the HOSTNAME AND PATH in the files listed in the instructions.  Tomcat shows that arcgis_js_jsapi is running.  Then I loaded the the arcgis webadaptor and configured it accourding to it's instructions.  Now I am trying the to test it using the test map HTML file given with the arcgis_js_jsapi instructions.
I doesn't work.
My Tomcat directories look like this:
My tomcat webapps directory look like this
[HTML]
\webapps
       \arcgis  /* this is the webadaptor
       \arcgis_js_jsapi  /* the javascript library
              \library
                   \3.2
                           \jsapi
                                  js
                                         \dgrid
                                         \dojo
                                         \esri
                                         \put-selector
                                         \xstyle
                           \jsapicompact
[/HTML]
I did not change anything in the any WEB-INF directories.  Should I?
This the test HTML I am using.
[HTML]
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>Test Map</title>
<link rel="stylesheet" type="text/css" href="http://gsdserver1:8090/arcgis_js_api/library/3.2/jsapi/js/dojo/dijit/themes/tundra/tundra.css"/>
    <link rel="stylesheet" type="text/css" href="http://gsdserver1:8090/arcgis_js_api/library/3.2/jsapi/js/esri/css/esri.css" />
    <script type="text/javascript" src="http://gsdserver1:8090/arcgis_js_api/library/3.2/jsapi/init.js"></script>
    <script type="text/javascript">
alert("before require");
      dojo.require("esri.map");
alert("after require");
      function init() {
  alert("Inside init")
        var myMap = new esri.Map("mapDiv");
        //note that if you do not have public Internet access then you will need to point this url to your own locally accessible cached service.
        var myTiledMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gsdserver1:8090/arcgis/rest/services/SampleWorldCities/MapServer");
        myMap.addLayer(myTiledMapServiceLayer);
alert("before onload")
      dojo.addOnLoad(init);
    </script>
</head>
<body class="tundra">
<h1> Test Map try # 1</h1>
    <div id="mapDiv" style="width:900px; height:600px; border:1px solid #000;"></div>
</body>
</html>
[/HTML]
OliviaZ
As I know so far, you can change the init.js file baseurl:[
https://localhost/arcgis_js_api/library/3.2/api
] and try it again. I am also working on that. Let me know if it is working to you.
