daglietti
Table to Excel geoprocessing service
Discussion created by daglietti on Dec 19, 2012
Latest reply on Dec 27, 2012 by jacobsj
I downloaded the Table to Excel geoprocessing tool from ArcGIS Online and I would like to publish it as a geoprocessing service.  My question is, how would I need to modify the script to accept an ArcGIS Javascript API FeatureSet as the input?  I see that the input parameter for the script is currently set to TableView.  I've changed it to be a "Feature Set" and modified the python code slightly to create the file in the Server's scratch workspace.  Unfortunately, when I call the function, I get this strange error reported in the server log:
updateParameters Execution Error: Runtime error : 'NoneType' object has no attribute 'lower'
I am guessing that my python code does work correctly against the FeatureSet object.  Anyone have any ideas?
Here is my python code:
# -*- coding: utf-8 -*-
   This script will convert a table to an excel spreadsheet. If the third-party
   module xlwt is available, it will use that. Otherwise, it will fall back to
   CSV.
import os
import sys
import arcpy
ver = arcpy.GetInstallInfo()['Version']
def header_and_iterator(dataset_name):
    """Returns a list of column names and an iterator over the same columns"""
    data_description = arcpy.Describe(dataset_name)
    fieldnames = [f.name for f in data_description.fields if f.type not in ["Geometry", "Raster", "Blob"]]
    def iterator_for_feature():
        if ver == u'10.0':
            cursor = arcpy.SearchCursor(dataset_name)
            row = cursor.next()
            while row:
                yield [getattr(row, col) for col in fieldnames]
                row = cursor.next()
            del row, cursor
        else:
            # leverage faster da cusors at 10.1
            with arcpy.da.SearchCursor(dataset_name, fieldnames) as cursor:
                for row in cursor:
                    yield row
    return fieldnames, iterator_for_feature()
def export_to_csv(dataset, output):
    """Output the data to a CSV file"""
    import csv
    def _encode(x):
        if isinstance(x, unicode):
            return x.encode("utf-8")
        else:
            return str(x)
    def _encodeHeader(x):
        return _encode(x.replace(".","_"))
    out_writer = csv.writer(open(output, 'wb'))
    header, rows = header_and_iterator(dataset)
    out_writer.writerow(map(_encodeHeader, header))
    for row in rows:
        out_writer.writerow(map(_encode, row))
def export_to_xls(dataset, output):
    Attempt to output to an XLS file. If xmlwt is not available, fall back
    to CSV.
    XLWT can be downloaded from http://pypi.python.org/pypi/xlwt"""
    try:
        sys.path.append(os.path.join(os.path.dirname(__file__), 'xlwt-0.7.4'))
        import xlwt
    except ImportError:
        arcpy.AddError("failed to import xlwt module")
        return
    # Make spreadsheet
    workbook = xlwt.Workbook()
    worksheet = workbook.add_sheet(os.path.split(dataset)[1])
    #Set up header row, freeze panes
    header_style = xlwt.easyxf("font: bold on; align: horiz center")
    for index, colheader in enumerate(header):
        worksheet.write(0, index, colheader.replace(".","_"))
    worksheet.set_panes_frozen(True)
    worksheet.set_horz_split_pos(1)
    worksheet.set_remove_splits(True)
    # Write rows
    for rowidx, row in enumerate(rows):
        for colindex, col in enumerate(row):
            worksheet.write(rowidx+1, colindex, col)
    workbook.save(output)
if __name__ == "__main__":
    dataset_name = arcpy.GetParameterAsText(0)
    scratch_path = arcpy.env.scratchWorkspace
    format = arcpy.GetParameterAsText(1)
    if format == "CSV":
        output_file = os.path.join(scratch_path,'lois_export.csv')
        export_to_csv(dataset_name, output_file)
        arcpy.SetParameterAsText(2,output_file)
    elif format == "XLS":
        try:
            output_file = os.path.join(scratch_path,'lois_export.xls')
            export_to_xls(dataset_name, output_file)
        except:
            import traceback
            arcpy.AddError(traceback.format_exc())
    else:
        raise ValueError("Don't know how to export to %r" % format)
Here is the javascript code that I call the service with:
function extractData(oidString,fileFormat){
    var query = new esri.tasks.Query();
    var qt = new esri.tasks.QueryTask(localServerPath + "/LOISOracle/MapServer/0");
    query.returnGeometry = false;
    query.where = "ESRI_OID in (" + oidString + ")";
    query.outFields = ["POINTNAME"];
    qt.execute(query, function (featureSet) {
        alert(featureSet.features.length);
        alert(fileFormat);
        var params = { "Input_Feature_Set":featureSet, "Format":fileFormat };
        esri.show(loading);
        gp.submitJob(params, completeCallback , statusCallback,function(error){
            alert(error.message);
            esri.hide(loading);
function completeCallback(jobInfo){
    if(jobInfo.jobStatus !== "esriJobFailed"){
      gp.getResultData(jobInfo.jobId,"Output_File", downloadFile);
function statusCallback(jobInfo) {
    var status = jobInfo.jobStatus;
    if(status === "esriJobFailed"){
      alert(status);
      esri.hide(loading);
    else if (status === "esriJobSucceeded"){
      esri.hide(loading);
David
Outcomes
