I have created a basic application for collecting infrastructure locations and attributes in the field using the trial subscription to ArcGIS Online and Desktop 10.1. I created domain values for an attribute field to record infrastructure ownership via a drop down list, symbolized the data by owner and posted this to ArcGIS online as a feature service.
From my iPhone this works exactly as I want it to. I can update attributes including the owner field and if I change the owner the symbol changes accordingly. However, when I try this from my PC I have problems. Although it correctly displays the owner information when I am not in edit mode, when I go into edit mode the owner field is blanked out. If I then pick an owner from the drop down list the symbol changes to one that I did not use in the map and this point then disappears from the iPhone view of the map.
Can anyone help me with this?
Thanks.
Thanks.
It appears that from my iPhone the system correctly uses the value from my drop down list while from my PC it uses the code instead of the value.
