AnsweredAssumed Answered
ArcGIS for Sharepoint can't access ArcGIS Online Web Maps shared with Organization
Question asked by mgregotskiesri-ca-esridist Employee on Dec 19, 2012
Latest reply on May 10, 2013 by zapper
I???m trying to use ArcGIS Online Subscription web maps containing ArcGIS Online Subscription feature services in ArcGIS for Sharepoint 2.1.1 and I???ve run into some trouble.
I have a web map that is shared with Everyone and contains a feature service that is also shared with Everyone. I can add this to the ArcGIS Web Map Part in ArcGIS for SharePoint through the Map Center successfully.  This is good.
I then have another Web Map that is shared with the Organization only and it contains a feature service that is shared with the Organization only.  When I try to add it to the ArcGIS Web Map Part in ArcGIS for SharePoint it gives me this error.
Layer Initialization Failure
Token Required
Error code ???499???: ???Token Required???
It seems that ArcGIS for Sharepoint can???t handle the token security that is being used by ArcGIS Online.  Has anyone got this to work before or know if this is a limitation to using ArcGIS for Sharepoint with ArcGIS Online?
Mike
Outcomes
