AnsweredAssumed Answered
Code review please - script never ends
Question asked by jpedder on Dec 19, 2012
Latest reply on Dec 19, 2012 by jpedder
Not sure how else to say it, but after running the code below, the processing window just flashes continually and the script doesn't ever appear to end. I have to kill ArcMap process to get out of the script.
I'm posting my entire code snippet below, hopefully someone can point out my error.
Warning, new Python coder here, please don't laugh "too hard' at my brute force coding attempts :p
# Jon Pedder # MapSAR - 12/15/12 # Make Briefing Map   import arcpy, os, glob  # Set enviroment # from arcpy import env    # Gather input parameters from user # 0. TargetFile mxd - string # 1. Folder to store pdf product - string # 2. Title of the Map - string # 3. Name of saved map - string # 4. Map Scale - string # 5. Center map on - list, string # 6. Use base data in current map - boolean  TargetFile = arcpy.GetParameterAsText(0) PDFlocation = arcpy.GetParameterAsText(1) aMapTitle = arcpy.GetParameterAsText(2) aMapName = arcpy.GetParameterAsText(3) aMapScale = arcpy.GetParameterAsText(4) aCenterMapOn = arcpy.GetParameterAsText(4) aBase_Data = arcpy.GetParameterAsText(6)  # Set Vars and overwrite option to true arcpy.env.overwriteOutput = True Targetmxd = None mxd = None  arcpy.AddMessage("Base data = " + aBase_Data)   ########################################  ###### BASE DATA COPY STARTS HERE      #  ########################################  # Gather information to copy over base_data  if aBase_Data == "true":      # Define vars    mxdlayer = "14 Base_Data_Group"   LayerFile = "C:\MapSAR\TempDir\Base_Layer"   LayerName = LayerFile + '.lyr'     # Save base_data layer file to disk in c:\MapSAR\TempDir from current mxd.   # If directory does not exist create it   if os.path.exists('c:\MapSAR\TempDir'):                arcpy.SaveToLayerFile_management(mxdlayer,LayerFile,"RELATIVE")       else:           os.makedirs('c:\MapSAR\TempDir')           arcpy.SaveToLayerFile_management(mxdlayer,LayerFile,"RELATIVE")    # Message to user           arcpy.AddMessage("Base Data Saved as "+ LayerFile)    Targetmxd = arcpy.mapping.MapDocument(TargetFile)    # Check for existing Base_Data layers in target. If present remove them   for df in arcpy.mapping.ListDataFrames(Targetmxd):          for lyr in arcpy.mapping.ListLayers(Targetmxd, "", df):              if 'Base_Data' in lyr.name:                   arcpy.mapping.RemoveLayer(df,lyr)                                      # Message to user that layers have been removed from target                   arcpy.AddMessage('removing '+ str(lyr) + ' from '+TargetFile)    # Message to user   arcpy.AddMessage('Loading Base_Data '+ LayerName +' from disk')    # Check if the layer exists on disk   if os.path.isfile(LayerName):           addLayer = arcpy.mapping.Layer(LayerName)           arcpy.mapping.AddLayer(df, addLayer, "BOTTOM")           Targetmxd.save()   else:           # If not alert user of an error           arcpy.AddMessage(LayerName +' does not exist')           ######################################## ###### BASE DATA COPY ENDS HERE        # ########################################  ######################################## ###### EXPORT MAP STARTS HERE          # ########################################   MapTitle = aMapTitle MapName = aMapTitle + ".pdf" MapLocation = PDFlocation + "/" + aMapName + ".pdf"  arcpy.AddMessage("Generating Briefing Map " + MapName) mxd = arcpy.mapping.MapDocument(TargetFile)  for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT","MapTitle"):  elm.text = "<BOL> " + MapTitle + "</BOL>"  for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT","MapName"):  elm.text = MapName  fc = "PLS_Subject_Information" # iQuery = "Name =" + aCenterMapOn iQuery = ' "Name" = \'Jon Pedder\' '  df = arcpy.mapping.ListDataFrames(mxd, "MapSAR")[0] lyr = arcpy.mapping.ListLayers(mxd, "PLS_Subject_Information", df)[0]  arcpy.AddMessage("Panning to center on PLS for "+ aCenterMapOn) # Use the SelectLayerByAttribute tool to select PLS Subject and  #  zoom to the selection arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", iQuery) df.zoomToSelectedFeatures() df.scale = aMapScale  # Export the map to a .pdf arcpy.mapping.ExportToPDF(mxd,MapLocation)  ######################################## ###### EXPORT MAP ENDS HERE            # ########################################  # Clear vars del mxd, Targetmxd
Outcomes
