I have found that if your map object has a basemap property set then the WMSLayer does not display when retrieving by resourceInfo method. When I do not set the basemap property then the WMSLayer is displayed.This is not very useful as I need to see the basemap. I dont know if this is a bug or me, I have no solution at the moment so if you know how to get round this please drop a line.Here is the url 'http://npdwms.npd.no/NPD_FactMap.asp' and layer is 'Quadrants' Here is my code<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Map with WMS</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<style>
html, body, #map {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
</style>
<script src="http://js.arcgis.com/3.9/"></script>
<script>
var map;
require(["esri/map", "esri/layers/WMSLayer", "esri/config","esri/layers/WMSLayerInfo","esri/geometry/Extent","esri/layers/FeatureLayer"],
function(Map, WMSLayer, esriConfig, WMSLayerInfo,Extent,FeatureLayer,parser) {
map = new Map("map", {
extent: new Extent({xmin:-8.64846,ymin:49.8638,xmax:1.76767,ymax:60.8612,spatialReference:{wkid:4326}}),
zoom: 2,
// basemap: "streets"
addNorway(WMSLayer,WMSLayerInfo,Extent);
addBGS(WMSLayer,WMSLayerInfo,Extent);
function addBGS(WMSLayer,WMSLayerInfo,Extent){
var layer20 = new WMSLayerInfo({name:"GBR_BGS_625k_BLS",title:"GBR BGS 1:625k Bedrock Lithology"});
var resourceInfo20 = {
extent: new Extent(-8.64846,49.8638,1.76767,60.8612,{wkid: 4326}),
layerInfos: []
var wmsLayer20 = new WMSLayer("http://ogc.bgs.ac.uk/cgi-bin/BGS_Bedrock_and_Superficial_Geology/wms",
resourceInfo: resourceInfo20,
visibleLayers: ["GBR_BGS_625k_BLS"]
map.addLayers([wmsLayer20]);
wmsLayer20.setVisibility(true);
function addNorway(WMSLayer,WMSLayerInfo,Extent){
var layer10 = new WMSLayerInfo({name:"Quadrants",title:"NO Quads"});
var resourceInfo10 = {
extent: new Extent(-10.0,50.0,20.0,65.0,{wkid: 4326}),
layerInfos: [layer10],
version:"1.1.1"
var wmsLayer10 = new WMSLayer("http://npdwms.npd.no/NPD_FactMap.asp",
{resourceInfo: resourceInfo10,
visibleLayers: ["Quadrants","pl_all","Fields","Exploration","Development"]
map.addLayers([wmsLayer10]);
</script>
</head>
<body>
<div id="map">
</div>
</body>
</html>
