Solved! Go to Solution.
Any webmap I open in ArcGIS Online seems to have a different extent (zoomed to full extent) than the last time we saved it. For example http://bit.ly/UgA6TQ - should be zoomed to where the data is. I have even opened, zoomed, saved and next time I open it is back to full extent.
I don't know if this has anything to do with it but we do not use any Esri basemap - we use our own aerial photo as the "base map" in the web map then add our operational layers. All had been fine until this last update.
Brandon
Hi Mike,
At Argyll and Bute Council, we use ESRI maps for customers submitting geographic based issues such as Fly Tipping.
Our maps are no longer initially focusing on the street a customer has searched for. The issues appears to be that initialExtent is not being set. Is this to do with the issue/fix you are mentioning here?
Jamie Robertson
