how to edit MaxRecordCount: 1000 in service of a feature layer
4502
6
12-14-2012 08:50 AM
GualbertoHernández_Juárez
I generated my service, a feature layer:
http://200.4.1.10:6080/arcgis/rest/services/test/MM5/MapServer/0
But I get by default "MaxRecordCount: 1000" and I need to increase it to 5000, can you tell me how?
Thank you very much.
Gualberto
wangzhifang
Stop your map service and go to the properties dialog of you map service, in Parameters tab, you could set the max return count of features of this map service. Ref: Maximum number of records returned by the server http://resources.arcgis.com/en/help/main/10.1/index.html#/Setting_map_service_properties/0154000003p...
MuhammadWaqar_ul_islam
New Contributor III
Search cfg file of ur map services edit in notepad
there u find
<Properties>
  <MaxRecordCount>1000</MaxRecordCount> change it 5000
restart ur services or restart system
hope it works for u
ElenaG
Hello
in my case I need to change the value to 5000 in the MaxRecordCount but in a specific layer, because the service is already at 5000 but on entering the json of the feature appears as 1000 and can not find where or how to change this value.
Anyone know what I can do? and follow the steps listed above.
thanks :confused:
SteveCole
Elena-
Did you ever solve your problem? I'm now facing the same thing- my map service has the 5,000 feature limit set but a layer within the service I REALLY need still shows 1,000.
Steve
RobertJones2
I have the same problem 😉 I've logged a support call so hopefully might have something to add here soon.
RobertJones2
It looks like this has been logged as a bug: http://support.esri.com/en/bugs/nimbus/TklNMDg2NDg1
'Changes made in the Maximum number of records returned by the server does not reflect the changes in the REST End Point for Layers within the Service.'
