bdial@hnrg.com
Import in_memory table to SQL Server non-spatial db
Discussion created by bdial@hnrg.com on Dec 14, 2012
Latest reply on Jan 6, 2013 by Wayne_Whitley
I've created a model which uses the in_memory workspace to speed up processing.  Utimately I need to pass the output to a table in a non-spatial SQL Server database.  A second reason for using the in_memory workspace is I don't want to store redundant data.  The idea is to pass the in_memory data directly to SQL Server so I don't have to create a feature class that is not needed (or that I will need to later delete).  Any input is appreciated.  Also, I'm not sure which forum would be most appropriate.  Thanks.
Outcomes
