I use the map.infoWindow.setFeatures to set 2 deferred in it.
But the deferred3 is 1 value, and the deferred4 is most of the time above the values. I dont want to keep clicking to the end just to see that result. But is there a way to set the deffered3 as first in the infowindow.
map.infoWindow.setFeatures([deferred3, deferred4]);
map.infoWindow.show(evt.mapPoint);
Here's some code where i set the deferred3 & 4.
deferred3.addCallback(function(response) {
// response is an array of identify result objects
// Let's return an array of features.
return dojo.map(response, function(result) {
var feature = result.feature;
feature.attributes.layerName = result.layerName;
//alert(result.layerName);
if(result.layerName === 'Op Urgentie'){
//alert("op urgentie");
console.log(feature.attributes.PARCELID);
var template = new esri.InfoTemplate("SO Nr ${SONUMMER}", "SO Nr: ${SONUMMER} <br/> RVO Nr: ${KLANTNUMMER} <br/> Urgentie: ${URGENTIE} <br/> Status: ${STATUS_PROMPT} <br/> Melding: ${DT_MELDING} <br/> <br/> Omschrijving: ${MELDINGSTEKST}");
feature.setInfoTemplate(template);
else if (result.layerName === 'niets'){
var template = new esri.InfoTemplate("", "Niets: ${Niets}");
return feature;
deferred4.addCallback(function(response) {
if(result.layerName === 'OBE Bladen'){
var template = new esri.InfoTemplate("OBE Blad ", "OBE Blad <br/> Barcode: ${Barcode} <br/> Uitgave: ${Uitgaveletter} <br/> Datum: ${Uitgavedatum} <br/> <br/> Link: <a href=" + "${Hyperlink}" + " target=_blank ;'>Klik hier om de tekening te bekijken</a>");
else if (result.layerName === 'OR Bladen'){
var template = new esri.InfoTemplate("OR Blad ", "OR Blad <br/> Barcode: ${Barcode} <br/> Uitgave: ${Uitgaveletter} <br/> Datum: ${Uitgavedatum} <br/> <br/> Link: <a href=" + "${Hyperlink}" + " target=_blank ;'>Klik hier om de tekening te bekijken</a>");
else if(result.layerName === 'OS Bladen'){
var template = new esri.InfoTemplate("OS Blad ", "OS Blad <br/> Barcode: ${Barcode} <br/> Uitgave: ${Uitgaveletter} <br/> Datum: ${Uitgavedatum} <br/> <br/> Link: <a href=" + "${Hyperlink}" + " target=_blank ;'>Klik hier om de tekening te bekijken</a>");
else if(result.layerName === 'BBKS Bladen'){
var template = new esri.InfoTemplate("BBKS Bladen ", "BBKS Blad <br/> Barcode: ${Barcode} <br/> Uitgave: ${Uitgaveletter} <br/> Datum: ${Uitgavedatum} <br/> <br/> Link: <a href=" + "${Hyperlink}" + " target=_blank ;'>Klik hier om de tekening te bekijken</a>");
else if(result.layerName === 'LBVL Bladen'){
var template = new esri.InfoTemplate("LBVL Bladen ", "LBVL Blad <br/> Barcode: ${Barcode} <br/> Uitgave: ${Uitgaveletter} <br/> Datum: ${Uitgavedatum} <br/> <br/> Link: <a href=" + "${Hyperlink}" + " target=_blank ;'>Klik hier om de tekening te bekijken</a>");
else if (result.layerName === 'Schema Bovenleiding (Geldig)'){
var template = new esri.InfoTemplate("Blad: ${Tekening}", " Blad: ${Tekening} <br/>Versie: ${Versie} <br/> Status: ${Status} <br/> Opmerking: ${Waarschuwing} <br/><br/> Link: <a href=" + "${Hyperlink}" + " target=_blank ;'>Klik hier om de tekening te bekijken</a> ");
else if (result.layerName === 'Schema Bovenleiding (Nog Niet Van Kracht)'){
return feature;
EDIT:
The deferred3 is a polygon, the deferred4 is polyline. Maybe there's is something for that?
