I am able to add a service that has a data layer with attachments and the attachments appear in the pop-up I've configured.
However, when I try to add a different data layer with a relationship class (and the table is saved in the mxd) I cannot use any of the fields in the related table for the pop-up. Is this a known limitation or is there a workaround?
Also, when I add a new data layer to a service with pop-ups that have already been configured, it messes up all of the pop-ups for
the other layers below the drawing...I'm assuming because it generates pop-ups best on the REST endpoint and I change those when a new layer is added. Does anyone know of a work around or solution? The services I manage will be updated regularly and it would be a shame to update pop-ups every time a new data source is added.
[ NIM084343 - Add support for table relates and relationship classes in hosted feature services ]
I'll look into the other issue you're seeing.
