Suzanne
Custom Error Handler
Discussion created by Suzanne on Dec 12, 2012
Latest reply on Dec 12, 2012 by Suzanne
I am a novice at programming but have been successful at writing some python code.  I am trying to write a custom error handler and have the error msg displayed in the in tool's process dialog box.  Message will print in python shell but not in process dialog box when run from a tool.
# import the required modules for the python script
import arcpy, os, sys, traceback
class NoCaseFld(Exception):
    pass
# define common variables here
caseFlds = "lU_CURRENT;TRACT"
caseOrder = "tract lucurrent"
orderErr = ""
fldFound = 1
try:
    # 1. If case field(s) selected, check for a specified sort order and create list object
    if caseFlds != "":
        if caseOrder != "":
            orderUpper = caseOrder.upper()
            if " " in orderUpper:
                orderList = orderUpper.split(" ")
            elif "," in orderUpper:
                orderList = orderUpper.split(",")
            elif ";" in orderUpper:
                orderList = orderUpper.split(";")
            else:
                fldFound = -1
                orderErr = caseOrder   #error in reading case field order
        # i. Verify sort order list values are found in case field(s) list
        caseUpper = caseFlds.upper()
        for f in orderList:
            for c in caseUpper.split(";"):
                if c == f:
                    fldFound = 1
                    continue
                else:
                    fldFound = -1
            if fldFound == -1:
                orderErr = orderErr + f
        if fldFound == -1:
            raise NoCaseFld
except NoCaseFld:
    print "Error: Case Field Name Order\nfield name(s) not found in table:\n" + orderErr
except:                             #error handeling code
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n     " + str(sys.exc_type) + ": " + str(sys.exc_value) + "\n"
    msgs = "ARCPY ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(msgs)
    arcpy.AddError(pymsg)
    print msgs
    print pymsg
    arcpy.AddMessage(arcpy.GetMessages(1))
    print arcpy.GetMessages(1)
Outcomes
