iaminsu12
geoprocessing tool execution problem
Discussion created by iaminsu12 on Dec 6, 2012
I try to make a new polygon with polygon and polyline, using Feature to Polygon tool.
fcBoundary is polygon IFeatureClass, and fcPairline is polyline IFeatureClass.
Below code does not work.
                        IGpValueTableObject vt = new GpValueTableObjectClass();
                        vt.SetColumns(2);
                        object weight;
                        weight = 1 as object;
                        object obj1 = fcBoundary;  //IFeatureClass fcBoundary
                        vt.AddRow(ref obj1);
                        vt.SetValue(0, 1, ref weight);
                        object obj2 = fcPairLine;      //IFeatureClass fcPairline
                        vt.AddRow(ref obj2);
                        vt.SetValue(1, 1, ref weight);
                        parameters = new VarArrayClass();
                        MessageBox.Show(fcDict["fcBoundary"]);
                        parameters.Add(vt);
                        parameters.Add("pM_"+i.getOri+"_"+i.getDes);
                        result = gp.Execute("FeatureToPolygon_management", parameters, null);
I got just COM error without any specification...
similar code worked well in other console application, but when I tried to migrate console application to ArcMap Add-in, there are so many codes that make errors..
Outcomes
