how to restrict road cars to move on pedestrial track in the same route?
634
12-05-2012 09:28 PM
Ayesha_
i am having roads and tracks in my network data....how can i make restriction so that road vehicle dont move towards pedestrian tracks.please answer
NicoleHanson
New Contributor III
First off, is there a reason you need both roads and pedestrian tracks?
You could try Hierarchies, making the ped tracks a high number so it's less likely to use.
Or you could load the pedestrian tracks as a restriction for line barriers (using the select by attribute tool).
Hope this helps!
JaySandhu
Hierarchy is not a way to restrict travel on some edges. The hierarchical algorithm may not favor the higher level hierarchy roads if the stops are close by.
Correct way is to have a restriction on edges that can be turned on or off for a particular mode of travel. Please see the tutorial data for Paris that sets up different modes and travel costs and restrictions for pedestrians.
http://resources.arcgis.com/en/help/main/10.1/#/Exercise_2_Creating_a_multimodal_network_dataset/004...
Jay Sandhu
