aconnolly
AGSGPS Auto Pan Modes
Discussion created by aconnolly on Dec 5, 2012
Latest reply on Dec 31, 2012 by aconnolly
I'm working with the GPS "facade" over Core Location in the ESRI SDK and I noticed something odd with the AGSGPSAutoPanModeCompassNavigation setting. You can create a simple app with a button that toggles between the different mode states and that is what I've done. I noticed that when transitioning from AGSGPSAutoPanModeCompassNavigation to AGSGPSAutoPanModeOff the map does not re-center on the user's location and worse the map remains rotated in the last direction/direction it was in prior to transitioning. Why does the map not auto-correct it's angle?
I know I can set the map rotationAngle property but it seems to me that the API should recognize this use case.
Finally, when manually setting the map rotationAngle in this case I can get the desired effect but my GPS location is often no longer centered. I'd rather not have to do a bunch of GIS math if possible to move the map to the correct spot when transitioning. Any ideas on what I might be doing wrong?
- Aaron
Outcomes
