Swipe tool
405
12-05-2012 04:18 AM
origudes
Hi there
I have created a swipe tool application using the following Web Map hosted in ArcGIS http://bit.ly/VCCghP
This is the template i have used: http://www.arcgis.com/home/item.html?id=dcaadc9aae1948c5b2df9adf8698f9cc
And this is the link to my application: http://gis03.rcs.griffith.edu.au/Swipe_Map_App/index.html
In the index HTML there is one row where you need to define what layer will disappear when moving the Swipe tool. Although, i have tried to change this parameter from 0 to 1 and to 2, it always just work on my SIEFA2006 layer or the Bing Map layer, i just can't do it for the T2_diabets layer (see the legend), can some one advise?
Cheers Ori
//Choose the layer that will disappear under the swipe tool. All layers are given a value from 0 to number of layers available in your map
  chooseSwipeLevel : "0",
origudes
Any suggestions?
BertrandLAURANCIN
your web map must contain feature services (LayerID with index)
Bertrand
