Turning layers on/off in my published web map
622
11-30-2012 05:24 AM
ErikBlake
Occasional Contributor III
I created a map on ArcGIS on-line and published it using the Basic map viewer that I downloaded from esri. My layers for my map are scale dependent that is some layers don't turn on till the map reaches a certain scale. Also when my map fires up I don't have my water and sewer layers on because it allows the map to open faster. So here is my question. after doing all my config with html I open my map and I am not able to have control on what layers I can turn off or on. it only allows for the layers that were on in my initial map when i published to show up. So how am I able to turn layers on/off in my published map
Erik
MikeMinami
Esri Notable Contributor
The basic viewer has a "layers" menu (unless you  turned it off) that lets  you turn layers on and off.
Mike
