coord_sys = arcpy.SpatialReference(r"D:\SueMonette\Geodesy\EPSG_Prj\2961.prj") transformation = "WGS_1984_(ITRF00)_To_NAD_1983 + NAD_1983_CSRS_to_WGS_1984_2" # Set new output coordinate system arcpy.Project_management(out_features, out_features_proj, coord_sys, transformation)
Generally speaking,
If you can get the project tool to do the job, then use the Model Builder cheat to give you the python syntax.
Set up a model in Model Builder with just the project tool, and enter the parameters that you know work.
You can even test it by running the model.
Now Export the model as a Python Script.
The script will give you the syntax with the inputs in place.
