engelalber
Adding Locations to a route by attribute
Discussion created by engelalber on Nov 29, 2012
Latest reply on Nov 30, 2012 by MMorang-esristaff
I'm hoping that someone can help with this problem: I have a network and a route analysis layer. I want to be able to use the "Add Locations" tool to add stops that have a particular name. I've tried using the Search Query parameter to select only the stops that have a particular string as an attribute, but the output of the tool is that every stop, regardless of what they have in that string attribute, is loaded into the routing layer. Any help? I'm using ArcGIS 10.1
Outcomes
