So here is the original # -*- coding: utf-8 -*-
This script will convert a table to an excel spreadsheet. If the third-party
module xlwt is available, it will use that. Otherwise, it will fall back to
CSV.
import arcgisscripting
import os
gp = arcgisscripting.create(9.3)
def header_and_iterator(dataset_name):
"""Returns a list of column names and an iterator over the same columns"""
data_description = gp.Describe(dataset_name)
fieldnames = [f.name for f in data_description.fields if f.type not in ["Geometry", "Raster", "Blob"]]
def iterator_for_feature():
cursor = gp.SearchCursor(dataset_name)
row = cursor.next()
while row:
yield [getattr(row, col) for col in fieldnames]
row = cursor.next()
del row, cursor
return fieldnames, iterator_for_feature()
def export_to_csv(dataset, output):
"""Output the data to a CSV file"""
import csv
def _encode(x):
if isinstance(x, unicode):
return x.encode("utf-8")
else:
return str(x)
def _encodeHeader(x):
return _encode(x.replace(".","_"))
out_writer = csv.writer(open(output, 'wb'))
header, rows = header_and_iterator(dataset)
out_writer.writerow(map(_encodeHeader, header))
for row in rows:
out_writer.writerow(map(_encode, row))
def export_to_xls(dataset, output):
Attempt to output to an XLS file. If xmlwt is not available, fall back
to CSV.
XLWT can be downloaded from http://pypi.python.org/pypi/xlwt"""
try:
import xlwt
except ImportError:
gp.AddError("import of xlwt module failed")
return
# Make spreadsheet
workbook = xlwt.Workbook()
worksheet = workbook.add_sheet(os.path.split(dataset)[1])
#Set up header row, freeze panes
header_style = xlwt.easyxf("font: bold on; align: horiz center")
for index, colheader in enumerate(header):
worksheet.write(0, index, colheader.replace(".","_"))
worksheet.set_panes_frozen(True)
worksheet.set_horz_split_pos(1)
worksheet.set_remove_splits(True)
# Write rows
for rowidx, row in enumerate(rows):
for colindex, col in enumerate(row):
worksheet.write(rowidx+1, colindex, col)
# All done
workbook.save(output)
if __name__ == "__main__":
dataset_name = gp.GetParameterAsText(0)
output_file = gp.GetParameterAsText(1)
format = gp.GetParameterAsText(2)
if format == "CSV":
export_to_csv(dataset_name, output_file)
elif format == "XLS":
try:
export_to_xls(dataset_name, output_file)
except:
import traceback
gp.AddError(traceback.format_exc())
else:
raise ValueError("Don't know how to export to %r" % format)
print "FINISHED"
and here is yours added. Did i get it right?# -*- coding: utf-8 -*-
CSV.
import os
row = cursor.next()
while row:
row = cursor.next()
del row, cursor
import csv
def _encode(x):
else:
return str(x)
for row in rows:
to CSV.
try:
import xlwt
except ImportError:
return
# Make spreadsheet
# Write rows
# All done
if format == "CSV":
try:
except:
import traceback
else:
print "Finished"
#start new script
import csv, os
table = r"C:\temp\python\XY.csv"
outFile = r"C:\temp\python\XY_1.csv"
outFile2 = r"C:\temp\python\XY_2.csv"
#read lines of CSV
f = open(table, "r")
lines=f.readlines()
lines=lines[1:]
f.close()
#write all lines except header to CSV
f = open(table, "w+")
for line in lines:
f.write(line)
f.close()
#remove first column
with open(table,"r") as input:
with open(outFile,"w+") as output:
writer=csv.writer(output)
for row in csv.reader(input):
writer.writerow(row[1:])
#remove empty rows
input = open(outFile, 'rb')
output = open(outFile2, 'wb')
writer = csv.writer(output)
if row:
writer.writerow(row)
input.close()
output.close()
os.remove(table)
os.remove(outFile)
#rename to original CSV
os.rename(outFile2, table)
print "Finished"
