CITYENGINE 2012 AUTHORIZED THEN SAYS IT ISN'T
3593
13
11-28-2012 07:09 AM
AaronHosford1
I installed the trial version on my laptop, windows 7 64 bit, and ran the authorization wizard.  Now when i open ArcGIS admin it says it is installed and authorized.  When i run the program it says CityEngine is not authorized for use and tells me to run the authorization process again.
Any help would be greatly appreciated.
MatthiasBuehler1
Hey there !
Do you have by chance ArcGIS 10.0 also installed on your system ?
Let me know ..
Matt
MatthiasBuehler1
NicoleHanson
New Contributor III
I am having this same issue.  I have installed the patch, and I have 10.0.  It still doesn't work.
MatthiasBuehler1
Hi !
Did you also set the -Dagol switch, as described here :
http://forums.arcgis.com/threads/68004-Trouble-starting-version-2012
Let me know ..
Matt
NicoleHanson
New Contributor III
It's still not letting me authorize CityEngine.  I did add that line.
MatthiasBuehler1
Hey Nicole !
Happy 2013 ! 🙂
Are you located in the U.S. ?
If so, please try calling the Esri Technical Support number you see here at the very bottom :
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/186/metaid/1929
If you're not in the U.S., let me know and I'll try to organize someone who can help you.
Let me know ..
Matt
NicoleHanson
New Contributor III
Hi Matt-
Yes, I'm in the US.  I currently have a concurrent license for Desktop.  My IT guy has been talking to ESRI tech support to get a concurrent license for the trial.
Thanks for your help.
Nicole
RobertCervellione
i am having the same issue. the i have a trial license, it is activated, but when i go to open the software it says its not activated. i do not have any other ersi software on the machine the trial is on. i also tried the license patch but still no luck
[ATTACH=CONFIG]21547[/ATTACH]
MatthiasBuehler1
Hi !
I've contacted Esri and somebody in their ranks will come and help you out !
Cheers !
Matt
