<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Mobile Popup</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{ padding: 20px 20px; } #map{ padding:0; } </style> <script type="text/javascript">var djConfig = {parseOnLoad: true};</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2compact"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.arcgis.utils"); dojo.require("esri.dijit.PopupMobile"); dojo.require("esri.IdentityManager"); var map,popup; function init() { esri.config.defaults.io.proxyUrl = "/EMAF/proxy/proxy.php"; //create a mobile popup popup = new esri.dijit.PopupMobile(null, dojo.create("div")); var mapDeferred = esri.arcgis.utils.createMap("3fc3f11514de4f9ab961dc9960d75388", "map", { mapOptions: { slider: true, nav:false, wrapAround180:true, infoWindow:popup } }); mapDeferred.addCallback(function(response) { map = response.map; //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); map.setExtent(new esri.geometry.Extent({"xmin":-52909106.87506947,"ymin":935889.3196982983,"xmax":-40483503.557034515,"ymax":7451993.106951275,"spatialReference":{"wkid":102100}})); }); mapDeferred.addErrback(function(error) { console.log("Map creation failed: ", dojo.toJson(error)); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> </div> </div> </body> </html>
Solved! Go to Solution.
