import arcpy, os def add2map (filename): """adds a layer to an existing map document that is located in the tooldata folder""" addLayer = arcpy.mapping.Layer(filename) arcpy.mapping.AddLayer(df,addLayer) #Add Selected Feature Classes to Map arcpy.SetProgressorLabel("Creating Map") printMessage("Creating map of selected counties and CA's in "+arcpy.env.workspace+"...") mapName = os.path.dirname(arcpy.env.workspace)+"/PCAmap.mxd" mxd = arcpy.mapping.MapDocument(mapName) ##mxd = arcpy.mapping.MapDocument("CURRENT")- tried this but it adds all layers to map not just the 2 I specify dfs = arcpy.mapping.ListDataFrames(mxd) df = dfs[0] #Convert selected conservation areas and counties to layer file #NOTE: Can not use OutputFL and pcaFL because it will map the all features with selected areas highlighted. selectedCounties = outName(OutputFC,"_Layer") selectedPCA = outName(pca_selected,"_Layer") arcpy.MakeFeatureLayer_management(OutputFC, selectedCounties) arcpy.MakeFeatureLayer_management(pca_selected,selectedPCA) #Apply symbology CountySymLayer = arcpy.env.workspace+"/Layers/WNC_Counties.lyr" PCAsymLayer = arcpy.env.workspace+"/Layers/PCA.lyr" arcpy.ApplySymbologyFromLayer_management(selectedPCA,PCAsymLayer) arcpy.ApplySymbologyFromLayer_management(selectedCounties,CountySymLayer) arcpy.SetParameterAsText(1,OutputFL) arcpy.SetParameterAsText(2,pcaFL) add2map(selectedCounties) add2map(selectedPCA) #Save a COPY of the map & export to jpg format mxd.saveACopy(outputWorkspace+os.sep+"PCA_COPY.mxd") printMessage("Map document of selected counties and selected PCA's saved to "+outputWorkspace) JPG = outputWorkspace+"/PCAmap_COPY.jpg" arcpy.mapping.ExportToJPEG(mxd,JPG) printMessage("JPEG of map docment saved to "+outputWorkspace) ##Remove Layers - tried removing the pre-analysis layers after mapping the selected layers but this doesn't work. ##lyrs = arcpy.mapping.ListLayers(mxd,"",df) ##lyr1 = lyrs[2] ##lyr2 = lyrs[3] ##arcpy.mapping.RemoveLayer(df,lyr1) ##arcpy.mapping.RemoveLayer(df,lyr2) arcpy.RefreshActiveView() arcpy.RefreshTOC() del mxd
Solved! Go to Solution.
arcpy.env.addOutputsToMap = True add2map(selectedCounties) add2map(selectedPCA) #Save a COPY of the map & export to jpg format mxd.saveACopy(outputWorkspace+os.sep+"PCA_COPY.mxd")
