EDNFreddy
SOE properties are reset to default values
Discussion created by EDNFreddy on Nov 26, 2012
I have a problem with the properties of a SOE. When I edit the properties in de services page and ovewrite the default values it works fine until I restart the service. The properties are reset to their default values and the service request is failing.
I use the SOE for two different mapservices. One mapservice uses the default properties and in the other service I configure the properties as needed. The mapservices are in two different folders. The SOE is written in Java and only exposes he REST endpoint. This is a 10.1 service.
Has anyone encountered this same problem and how did you fix it? Or is this a bug?
My workaround would be to convert the properties to service parameters but that's my last resort.
Any help is appreciated!
Greetings,
Freddy
Outcomes
