Hi,Following on from a netCDF file generated several raster and then built a mosaic dataset, finally need to add time for each raster that form the mosaic.Create the following code but I added the last time all previous raster.I need each raster has its respective time. (the problem is in the last part of the code)Can you help?thank you very muchGualbertoimport arcpy
import glob, os
import time
from time import localtime, strftime
tic = time.clock()
#*********** PRINCIPALES VARIABLES *************
prefijo = "sde.SDE."
Nommosaico = "test"
variable = "pslv"
outLoc = "Database Connections/Coneccion local SDE.sde/"
inNetCDF = "C:/IIE_Datos/Prediccion/Ejemplomosaico/MMOUT_DOMAIN1.nc"
ESTADOS_shp = "C:\\IIE_Datos\\Prediccion\\Ejemplomosaico\\Mapa república Mexicana\\ESTADOS.shp"
Coneccion_local_SDE_sde = "Database Connections\\Coneccion local SDE.sde"
# Process: Create Mosaic Dataset
arcpy.CreateMosaicDataset_management(outLoc, Nommosaico, "PROJCS['Lambert_Conformal_Conic',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',-27.0],PARAMETER['Central_Meridian',-124.17],PARAMETER['Standard_Parallel_1',0.0],PARAMETER['Standard_Parallel_2',0.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Kilometer',1000.0]];-20037.7 -30225.3 149134210447.956;1 1;1 1;0.000001;2;2;IsHighPrecision", "", "")
# Process: Add Field
arcpy.AddField_management(outLoc + Nommosaico, "tiempo", "DATE", "", "", "", "T", "NULLABLE", "NON_REQUIRED", "")
nc_FP = arcpy.NetCDFFileProperties(inNetCDF)
nc_Dim = nc_FP.getDimensions()
test = outLoc + '/*'
r = glob.glob(test)
list = []
for i in r:
os.remove(i)
for dimension in nc_Dim:
top = nc_FP.getDimensionSize(dimension)
for i in range(0, top):
if dimension == "time":
dimension_values = nc_FP.getDimensionValue(dimension, i)
daat = "time '"+str(dimension_values)+ "'"
print daat
nowFile = str(i)
testt = dimension_values.replace("/","").replace(":","").replace(".","").replace("'","").replace(' ','')
print testt
rast = "time" + nowFile
#print rast
# Convierte todos los tiempos del NETCDF A LAYER
arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, "lon", "lat", testt, "", daat, "BY_VALUE")
#CONVIERTE LAS LAYER A RASTER Y LOS GUARDA EN EL DIRECTORIO INDICADO
arcpy.CopyRaster_management(testt, outLoc + rast, "", "", "-3,402823e+038", "NONE", "NONE", "", "NONE", "NONE")
# Local variables:
Build_Raster_Pyramids = "true"
Calculate_Statistics = "true"
# Process: Add Rasters To Mosaic Dataset
arcpy.AddRastersToMosaicDataset_management(outLoc + Nommosaico, "Raster Dataset", outLoc + rast, "UPDATE_CELL_SIZES", "NO_BOUNDARY", "NO_OVERVIEWS", "", "0", "1500", "", "", "SUBFOLDERS", "ALLOW_DUPLICATES", Build_Raster_Pyramids, Calculate_Statistics, "NO_THUMBNAILS", "")
fech = str(dimension_values)
vv = time.strftime(fech)
# CREA UNA LISTA DE TODOS LOS RASTER CREADOS, PARA DESPUES UNIRLOS EN UNO SOLO
list.append(vv)
updateRows = arcpy.UpdateCursor(outLoc + Nommosaico)
for updateRow in updateRows:
updateRow.tiempo = vv
updateRows.updateRow(updateRow)
del updateRow, updateRows
#print list
toc = time.clock()
print toc - tic
