Read geometry from JSON object
11035
5
11-24-2012 06:52 AM
XintaoLiu
Occasional Contributor II
In Flex 3, I convert a featureset (including several simple polygons) to JSON object: var geomJSON:Object = myFeatureSet.toJSON();
Then I pass the geomJSON as a parameter to a web service (developed using VS2010 C# language). Now the problem is: how to read the polygons as ESRI IPolygon inside the C# web service? What kinds of ESRI classes should I use?
Many thanks in advance! And sorry for the cross posting.
TomSchuller
Occasional Contributor III
IvanBespalov
http://json.org/ - scroll page down and you'll see JSON utilities links for C#.
UPD
ArcObjects Help for Java - com/esri/arcgis/server/json package
ArcObjects API Reference for .NET - JSONObject Class
EstherColero
New Contributor III
Hello Xinato,
You need the class ESRI.ArcGIS.SOESupport.Conversion. I use this code in Desktop, but probably it works for you. Try something like this:
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.SOESupport;
public class JSonBiz
 private const string JSON_GEOMETRY = "geometry";
 private const string JSON_SPATIAL_REFERENCE = "spatialReference";
 private const string JSON_RINGS = "rings";
 private const string JSON_PATHS = "paths";
 private const string JSON_POINTS = "points";
 private const string JSON_Z = "z";
 public static IGeometry ToGeometry(string strJson)
  IGeometry pGeometry = null;
  JsonObject pJsonObject = null;
  JsonObject pJsonObjectGeometria = null;
  JsonObject pJsonObjectSpatialReference = null;
  ISpatialReference pSpatialReference = null;
  try {
   //Parse
   pJsonObject = new JsonObject(strJson);
   //Get geometry
   if (pJsonObject.TryGetJsonObject(JSON_GEOMETRY, pJsonObjectGeometria)) {
    pGeometry = getGeometry(pJsonObjectGeometria);
    //Set spatial reference
    if ((pGeometry != null) && pJsonObject.TryGetJsonObject(JSON_SPATIAL_REFERENCE, pJsonObjectSpatialReference)) {
     pSpatialReference = Conversion.ToSpatialReference(pJsonObjectSpatialReference.ToJson());
     if ((pSpatialReference != null)) {
      pGeometry.SpatialReference = pSpatialReference;
  } catch (Exception ex) {
   pGeometry = null;
   //Maybe show your own error
  return pGeometry;
 private static IGeometry getGeometry(JsonObject jsonObjectGeometry)
  IPoint pPoint = null;
  IZAware pZAware = default(IZAware);
  double dblZ = 0;
  object[] objArray = null;
  //Test all
  if (jsonObjectGeometry.TryGetArray(JSON_RINGS, objArray)) {
   //Polygon
   pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryPolygon);
  } else if (jsonObjectGeometry.TryGetArray(JSON_PATHS, objArray)) {
   //Polyline
   pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryPolyline);
  } else if (jsonObjectGeometry.TryGetArray(JSON_POINTS, objArray)) {
   //Multipoint
   pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryMultipoint);
  } else {
   //Point
   try {
    pPoint = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryPoint);
    //z value
    if (jsonObjectGeometry.Exists(JSON_Z) && jsonObjectGeometry.TryGetAsDouble(JSON_Z, dblZ)) {
     //Test value
     if (double.IsNaN(dblZ)) {
      dblZ = 0;
     //Set value
     pZAware = pPoint;
     pZAware.ZAware = true;
     pPoint.Z = dblZ;
    pGeometry = pPoint;
    pGeometry = null;
   //Envelope
   if (pGeometry == null) {
    try {
     pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryEnvelope);
    } catch (Exception ex2) {
     pGeometry = null;
  //Simplify (Maybe you don't need it)
  if ((pGeometry != null)) {
   ITopologicalOperator pTopologicalOperator = pGeometry;
   pTopologicalOperator.Simplify();
  return pGeometry;
 public static string ToJSon(ref IGeometry pGeometry)
  string strJson = null;
  strJson = System.Text.Encoding.ASCII.GetString(ESRI.ArcGIS.SOESupport.Conversion.ToJson(pGeometry));
  return strJson;
Hope it helps.
Regards
Esther
TomSchuller
ChristinaMosnick
The original link is broken.  Here is the updated link I think..
XintaoLiu
Thank all you guys!
