I have a grid. I need to display it is classified by DefinedInterval. Method is set to normal, and the interval is calculated by itself.
In the description of the method is said that you first need to set the interval and then assign method (?), But how is not clear.
code:
Public Function ClassifyRenderer1(ByVal rasterDataset As ESRI.ArcGIS.Geodatabase.IRasterDataset, nummeclass As Integer) As IRasterRenderer
Try
'Create the classify renderer.
Dim classifyRenderer As IRasterClassifyColorRampRenderer = New RasterClassifyColorRampRendererClass()
classifyRenderer.ClassCount = nummeclass
Dim rasterRenderer As IRasterRenderer = CType(classifyRenderer, IRasterRenderer)
'Set up the renderer properties.
Dim raster As IRaster = rasterDataset.CreateDefaultRaster()
rasterRenderer.Raster = raster
Dim pRasterBC As IRasterBandCollection = CType(rasterRenderer.Raster, IRasterBandCollection)
Dim pRasterBand As IRasterBand = pRasterBC.Item(0)
pRasterBand.ComputeStatsAndHist()
rasterRenderer.Update()
'set classfication method
Dim pClassProp As IRasterClassifyUIProperties
pClassProp = classifyRenderer
Dim pUID As UID
Dim ClassBreak As Object
Dim pClassify As IClassifyGEN
pClassify = New DefinedInterval
Dim pInterval As IIntervalRange2 = pClassify
pInterval.IntervalRange = 25
ClassBreak = pClassify.ClassBreaks
pUID = pClassify.ClassID
pClassProp.ClassificationMethod = pUID
rasterRenderer = classifyRenderer
'Set the color ramp for the symbology.
Dim colorRamp As IAlgorithmicColorRamp = New AlgorithmicColorRampClass
Dim startColor As IRgbColor
Dim endColor As IRgbColor
startColor = New RgbColor
endColor = New RgbColor
startColor.Red = 209
startColor.Green = 144
startColor.Blue = 21
endColor.Red = 7
endColor.Green = 218
endColor.Blue = 7
'Set the Start and End
'Colorsalg()
colorRamp.ToColor = startColor
'alg()
colorRamp.FromColor = endColor
'Set the ramping Alglorithm alg
colorRamp.Algorithm = esriColorRampAlgorithm.esriCIELabAlgorithm
'Set the size of the ramp (the number of colors to be derived)alg
colorRamp.Size = nummeclass
'Create the rampalg
colorRamp.CreateRamp(True)
' Dim createColorRamp As Boolean
'colorRamp.CreateRamp(createColorRamp)
'Create the symbol for the classes.
Dim fillSymbol As IFillSymbol = New SimpleFillSymbolClass()
Dim pFSymbol As IFillSymbol
pFSymbol = New SimpleFillSymbol
Dim i As Integer
For i = 0 To classifyRenderer.ClassCount - 1 Step i + 1
pFSymbol.Color = colorRamp.Color(i)
classifyRenderer.Symbol(i) = CType(pFSymbol, ISymbol)
' classifyRenderer.Label(i) = Convert.ToString(i)
Return rasterRenderer
Catch ex As Exception
System.Diagnostics.Debug.WriteLine(ex.Message)
Return Nothing
End Try
End Function
