I need to create 300m isochrones for around 2800 bus stops. But for this particular data the generation process is taking too long and stops responding after a while. Please can anyone let me know what could be the reason for this.
I have tried this process before and it has worked fine for other data.
There is enough space in C drive. I tried splitting the bus stops into different shapefiles and run isochrone generation. But not got the result.
Regards
Anand
Regards
Anand
Arcgis is sometimes slow. But it does the job. May be wait a little longer, the number of stops you have is a big number. Else check your connectivity before you run the tool.
regards,
