AnsweredAssumed Answered
ERROR 000824: The tool is not licensed.  in arcpy.Contour_3d
Question asked by eltopo on Nov 16, 2012
Latest reply on Nov 20, 2012 by eltopo
I am using "arcpy.Contour_3d" and get an error, and review in detail the parameters and apparently all is well I hope you can help me
thank you very much
# -*- coding: utf-8 -*- # --------------------------------------------------------------------------- # test contours.py # Created on: 2012-11-16 14:51:29.00000 #   (generated by ArcGIS/ModelBuilder) # Description:  # ---------------------------------------------------------------------------  # Import arcpy module import arcpy  # Check out any necessary licenses arcpy.CheckOutExtension("3D")   # Local variables:  sde_SDE_time0__3_ = "Database Connections\\Coneccion local SDE.sde\\sde.SDE.time0" time1 = "Database Connections\\Coneccion local SDE.sde\\time1"   # Process: Contour arcpy.Contour_3d(sde_SDE_time0__3_, time1, "2", "0", "1")
I get:
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\ddd.py", line 3612, in Contour
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
Failed to execute (Contour).
Outcomes
