Are there any known issues with a Mixed Tile format tile package and the SDK? I have a 200~ MB tile package that's included with the project and has 20 or so scale levels worth of imagery. However zooming in past a certain scale level causes the tile imagery to disappear. Here is a bit more data on the tile package we're using. I can also share it and the project with you via DropBox if you'd like.
- The tile package has been created from a File Geodatabase source data using ArcGIS 10.1 no service packs.
- The tile scheme used is ArcGIS Online/Bing Maps/Google Maps
- There were 19 levels that were created and the smallest scale level is 1:1128.49
- The tiles were created in Mixed tile format
- All levels are visible when the Tile Package is viewed as an ArcGISLocalTiledLayer within an ArcGIS Runtime SDK 1.0 for WPF application.
- All layers are visible at all times.
- The minimum scale level for the labels to be visible is set to be 1:15,693 or lower.
- Aaron
