AnsweredAssumed Answered
Point Denisty Output Conversion To Polygon
Question asked by chrismeister on Nov 14, 2012
Latest reply on Nov 14, 2012 by chrismeister
Hallo everybody,
with my point shapefile i created a point density raster which i want to convert to polygon (Raster to Polygon, in the Conversion Tools). i changed nothing at the raster output - But when i try it, an error occurs which is not very helpful for me.
000864 : <value>: The input is not within the defined domain. <value>
ArcGIS 10
Description
The specified input is not valid for the parameter. You might have tried to use a value for the parameter that is not one of the defined options or is not a valid type or perhaps made a typing error. The command syntax will identify the valid options for each function. For example, the options for the Filter type parameter are only LOW or HIGH. No other text string will be accepted.
Solution
Check the syntax and documentation to make sure you are specifying the command correctly and that the input types are valid.
mabye it's an basic and easy problem to fix but i',m a beginner on the field of raster files.
Best regards
Outcomes
