dbutz
Bug when publishing tiled map service with labels
Discussion created by dbutz on Nov 14, 2012
Latest reply on Nov 15, 2012 by dbutz
I have a simple polygon layer that I have in ArcMap. I labeled it using a simple VBScript expression to make a label such as "ID: [myIDField] so it will show 'ID: 234' for example.
After I publish this to ArcGIS Online as a tiled map service, the labels appear but only show the part of the label in quotes and NOT the part of the label pulled from the attribute table. So I only see "ID:" after publishing.
Why is this?
Outcomes
