... dsets = arcpy.ListDatasets("*","Feature") for dataset in dsets: if "contour" in dataset: dsets.remove(dataset) for ds in dsets: print ds ...
dsets = [ds for ds in arcpy.ListDatasets("*","Feature") if "contour" not in ds]
dsets = arcpy.ListDatasets("*","Feature") if "contour" in dsets: dsets.remove("contour")
dsets = [ds for ds in arcpy.ListDatasets("*","Feature") if ds != "contour"]
you could try this:... dsets = arcpy.ListDatasets("*","Feature") rsets = [] for dataset in dsets: if dataset != "contour": rsets.append(dataset) for ds in rsets: print ds ...
>>> arcpy.env.workspace=("e:/test") >>> ld = arcpy.ListDatasets("*","Raster") >>> print ld [u'myrasout.asc', u'ras_test2', u'ras_test22.asc', u'ras_test22.tif', u'ras_test2_2', u'ras_test3', u'ras_test3_3'] >>> for l in ld: ... if "myrasout" in l: # the one i´d like to filter out ... ld.remove(l) ... >>> print ld [u'ras_test2', u'ras_test22.asc', u'ras_test22.tif', u'ras_test2_2', u'ras_test3', u'ras_test3_3']
ld1 = [ds for ds in arcpy.ListDatasets("*","Raster") if "myrasout" not in ds] >>> print ld1 [u'ras_test2', u'ras_test22.asc', u'ras_test22.tif', u'ras_test2_2', u'ras_test3', u'ras_test3_3']
curious as to what´s bugged/why my code doesn´t work for you.
"ras_test2" in l
for l in list(ld): if l == "contour": ld.remove(l)
What threw me of is your use of the "in" operator to compare strings. Your code would remove "contours","contour1", and "xcontour" because you are using "in" instead of "==" in your remove test
