dbrandon
IRasterStretchColorRampRenderer question
Discussion created by dbrandon on Nov 9, 2012
All:
I have a stand alone application written in C# that tries to set a renderer for a raster image that is being created.  Basically, the code is very simple and looks something along the lines of:
 // Customize how the raster renders.
 IRasterStretchColorRampRenderer mRenderer = new RasterStretchColorRampRenderer();
 mRenderer.ColorScheme = "Blue Light to Dark";
// Code to generate the raster here...
// Create the raster layer and set the renderer.
m_rasLayer.CreateFromRaster(outputRaster);
m_rasLayer.Renderer = (IRasterRenderer)mRenderer;
// Add the layer to the last position in the table of contents.
m_hookHelper.FocusMap.AddLayer(rasLayer);
m_hookHelper.FocusMap.MoveLayer(rasLayer, map.LayerCount - 1);
activeView.PartialRefresh(esriViewDrawPhase.esriViewGeography, null, null);
Furthermore, in the application, the user can select the raster layer and change the sybology through a dialog.  It has a similar way of setting the raster renderer...
// A method that returns a valid renderer.
IRasterStretchColorRampRenderer rasterStretchRenderer = myFramework.symbolForm.GetRasterStretchRenderer(rasterLayer);
if(rasterStretchRenderer == null)
return;
// Set the renderer.
rasterLayer.Renderer = (IRasterRenderer)rasterStretchRenderer;
In both instances, the IRasterStretchColorRampRenderer holds the values I expect to see right before the call to set the renderer, i.e. rasterLayer.Renderer = (IRasterRenderer)rasterStretchRenderer;
However, the moment that call is made, the values are blown away and the default black to white renderer is displayed in the map.  Any idea why this would be happening?
Thanks...
Outcomes
