Jastro
MapControlClass and License. Fails with COM Exception 80040112 (Editor License)
Discussion created by Jastro on Nov 6, 2012
Hi folks,
I wanted to test my Map application with several maps, just using ArcEditor License (Concurrent Use) without any Engine (No Runtime or Developer Kit running/licensed). In my opinion this should work.
I am using AOInitialize with Editor License in App.xaml to init the license. My main map is running properly, but I don't use MapControlClass in this case. MapControlClass is used within a method to copy layers out of my main map into a new mxd file.
Heres the code:
IMapDocument pIMapDoc = null;
IMapControl2 pIMapCtl = null;
try{
     pIMapCtl = new MapControlClass();
     pIMapCtl.Map = _mapControl.Map;
     IMxdContents pIMxd = (IMxdContents)pIMapCtl;
     pIMapDoc = new MapDocumentClass();
     pIMapDoc.New(pathToMapDocument.FullName);
     pIMapDoc.ReplaceContents(pIMxd);
     pIMapDoc.Save(false, false);
 finally{
      if (pIMapDoc != null)
           Marshal.ReleaseComObject(pIMapDoc);
      if (pIMapCtl != null)
           Marshal.ReleaseComObject(pIMapCtl);
Code crashes in line:
Error Code is:
HRESULT: 0x80040112
I found out that everything works fine until I do the following during Initialisation of the new MapWindow:
((System.ComponentModel.ISupportInitialize)(this.axMapControl1)).EndInit();
Does anybody had this problem too and knows how to solve it? I am sure that my License is initialised and on ArcEditor.
Thanks in advance!
Jan
Outcomes
