rschuil
Location-Allocation
Discussion created by rschuil on Nov 6, 2012
Latest reply on Nov 6, 2012 by jsandhu-esristaff
I would like to know how to use the weight for demand points. Starting point is to minimize facilities with a certain impedance cutoff. Some of the demand points in a specified area (high classified) need a weight which is 2,66 times higher then normal. What options must be selected or done to calculate that the facilities will be more close to the high classified areas then the normal.
Could someone explain how this works?
Greetings Robert
Outcomes
