Hi,I am trying to save (and load) IPersistStream into byte[] format in SQL Server. But, I got an error: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) in the loading function.Please see my below codes:public void save(AxPageLayoutControl pageControl)
IPersistStream perStream;
IMemoryBlobStream mebStream = new MemoryBlobStreamClass();
IGraphicsContainer graphicsContainer = pageControl.ActiveView.GraphicsContainer;
graphicsContainer.Reset();
IElement pElement = graphicsContainer.Next();
while (pElement != null)
if (pElement is IMapFrame)
perStream = (IPersistStream)pElement;
perStream.Save(mebStream, 0);
byte[] map = new byte[mebStream.Size];
mebStream.AttachToMemory(map [0], (uint)map .Length, 0);
// codes to insert "map" into a sql table
break;
For loading:public void load(AxPageLayoutControl pageControl)
// Get byte[] data from database (execute a select statement)
byte[] map = GetDataFromDatabase();
mebStream.ImportFromMemory(map [0], (uint)map .Length);
perStream.Load(mebStream); // Throw error
IMapFrame frame = new MapFrameClass();
frame = (IMapFrame)perStream;
pElement = (IElement)frame;
break;
pageControl.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
Are there anyone can help ?Thanks and regards,
