cpicciri
GIS Server connection woes
Discussion created by cpicciri on Oct 30, 2012
Latest reply on Oct 31, 2012 by cpicciri
Hi everyone,
This is my first attempt to connect to a GIS Server so my error is probably something simple but cannot figure it out. I followed the example in this link: http://edndoc.esri.com/arcobjects/9.2/NET_Server_Doc/developer/ArcGIS/ArcObjects/connect_gis_server.htm
amongst others.
I am using the code below but it fails on the connect line with an error of "Identity Error: Server could not authenticate the supplied identity."
ESRI.ArcGIS.ADF.Identity identity = new ESRI.ArcGIS.ADF.Identity("pub", "pub", ".");
ESRI.ArcGIS.ADF.Connection.AGS.AGSServerConnection ags_connection;
ags_connection = new ESRI.ArcGIS.ADF.Connection.AGS.AGSServerConnection("http://services.nationalmap.gov/ArcGIS/services", identity);
ags_connection.Connect();
IServerObjectManager som = ags_connection.ServerObjectManager;
If I load the layer manually in ArcMap and look at the Source tab for the layer, the info I get is this:
Data Type: ArcGIS Map Service
Connection:   Internet
Server:   http://services.nationalmap.gov/ArcGIS/services
User:  pub
Operations Allowed:  Map (Display), Query (Identify), Data (Find)
Map Service Type:  Not Cached
Coordinate System: GCS_WGS_1984
Datum:  D_WGS_1984
Prime Meridian:  0
Can someone point me in the right direction?
Carlos
Outcomes
