beaconofhope
"Changing Feature Type" Error when editing symbolized field
Discussion created by beaconofhope on Oct 29, 2012
Latest reply on Jul 28, 2016 by vholdener
I have a feature service (point feature class) with several fields that have domains.  The map is symbolized to show Property
Description-Lot, Structure, or Null.  If I select a value the phone will return the error message "Changing Feature Type- You are changing the feature type, which may potentially overwrite some field values.  Are you sure you want to do this?".  If I select yes it changes all the other fields.  If I edit the fields that are not symbolized then it is fine.  I could set the symbology to a non-edited field.  But we are working with many community members, and we would like for them to know that when the point changes colors then the
data has been recorded.
Outcomes
