sabo111
Measurement widget problem
Discussion created by sabo111 on Oct 29, 2012
Latest reply on Oct 29, 2012 by reddaiah.purma
I am using the measurement widget in my program. However, it seems to not be able to show the results after drawing the graphics. It works only for measuring of location, measurement for distance or area does not seems to work. Please help me find my error from the codes below thank you.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
      Measure Tool
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
      #map {
        border:solid 2px #808775;
        -moz-border-radius:4px;
        -webkit-border-radius:4px;
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:240px;
      .claro .dijitTitlePaneTitle {
        background: #808775;
        font-weight:600;
        border:solid 1px #29201A;
      .claro .dijitTitlePaneTitleHover {
        background:#808775;
      .claro .dijitTitlePaneTitleActive {
        background:#808775;
      .claro .dijitTitlePaneContentOuter {
        border-right: solid 2px #808775 !important;
        border-bottom: solid 2px #808775 !important;
        border-left: solid 2px #808775 !important;
      </style>
      <script type="text/javascript">
        djConfig = {
          parseOnLoad:true
      </script>
      <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
   <script type='text/javascript' src='http://www.onemap.sg/API/JS/?accessKEY=xkg8VRu6Ol+gMH+SUamkRIEB7fKzhwMvfMo/2U8UJcFhdvR4yN1GutmUIA3A6r3LDhot215OVVkZvNRzjl28TNUZgYFSswOi&v=2.8&type=full'></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.TitlePane");
      dojo.require("dijit.form.CheckBox");
      dojo.require("esri.map");
      dojo.require("esri.dijit.Measurement");
      dojo.require("esri.SnappingManager");
      dojo.require("esri.dijit.Scalebar");
      dojo.require("esri.layers.FeatureLayer");
      var map;
   var OneMap = new GetOneMap('map','SM');
      function init() {
       //This sample may require a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
        //esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
        //esri.config.defaults.io.alwaysUseProxy = false;
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        //esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
  esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://www.onemap.sg/ArcGIS/rest/services/Geometry/GeometryServer");
       //var initialExtent = new esri.geometry.Extent({"xmin":-9545482,"ymin":4615382,"xmax":-9544248,"ymax":4616059,"spatialReference":{"wkid":102100}});
        //map = new esri.Map("map", {
          //extent:initialExtent
        dojo.connect(OneMap.map, 'onLoad', function(map) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
        /*var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
        map.addLayer(basemap);
        var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
         new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
         new dojo.Color([195,176,23]), 2),null);
        var parcelsLayer = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer/0", {
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
        parcelsLayer.setRenderer(new esri.renderer.SimpleRenderer(sfs));
        dojo.connect(map, "onLayersAddResult", function(results){
          //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac.
          var snapManager = map.enableSnapping({snapKey:dojo.keys.copyKey});
          var layerInfos = [{layer: parcelsLayer}];
          snapManager.setLayerInfos(layerInfos);*/
          var measurement = new esri.dijit.Measurement({
            map: OneMap.map
          }, dojo.byId('measurementDiv'));
          measurement.startup();
        //map.addLayers([parcelsLayer]);
      //show map on load
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:'false'"
    style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
Outcomes
