I use nliu's Basemap Control (same author of TOC and googlelayer). Its very similiar, but has way more functionality and is super easy to configure.
what is the difference between just ArcGIS server serving out map services and application and an internal portal? Any documentation?
Jeff,
I am looking to emulate the Map item gallery so users can select the mapping application that they need... much like whaqt you see when you go to the code gallery for this API... also, greetings from Texas we may have meet a while back when I worked in Hillsborough County. Cheers
