eltopo
Script that runs perfectly in ArcMap version 10 does not in version 10.1
Discussion created by eltopo on Oct 26, 2012
Latest reply on Oct 26, 2012 by eltopo
Hi all,
develop a script that runs perfectly in ArcMap version 10, and when I run the same script on machine with version 10.1 is the following error:
(I hope you can help me to resolve it)
Thans,
Gualberto
>>> import arcpy
import glob, os
#*********** PRINCIPALES VARIABLES *************
prefijo = "sde.SDE."
Nommosaico = "mostest8"
variable = "pslv"
outLoc = "C:/IIE_Datos/Prediccion/Ejemplomosaico/test.mdb/"
inNetCDF = "C:/IIE_Datos/Prediccion/Ejemplomosaico/MMOUT_DOMAIN1.nc"
# Process: Create Mosaic Dataset
arcpy.CreateMosaicDataset_management(outLoc, Nommosaico, "PROJCS['Lambert_Conformal_Conic',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',-27.0],PARAMETER['Central_Meridian',-124.17],PARAMETER['Standard_Parallel_1',0.0],PARAMETER['Standard_Parallel_2',0.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Kilometer',1000.0]];-20037.7 -30225.3 149134210447.956;1 1;1 1;0.000001;2;2;IsHighPrecision", "", "")
variable = "pslv"
nc_FP = arcpy.NetCDFFileProperties(inNetCDF)
nc_Dim = nc_FP.getDimensions()
test = outLoc + '/*'
r = glob.glob(test)
for i in r:
   os.remove(i)
for dimension in nc_Dim:
    top = nc_FP.getDimensionSize(dimension)
    for i in range(0, top):
        if dimension == "time":
            dimension_values = nc_FP.getDimensionValue(dimension, i)
            daat = "time '"+str(dimension_values)+ "'"
            print daat
            #nowFile = str(dimension_values)
            nowFile = str(i)
            testt = dimension_values.replace("/","").replace(":","").replace(".","").replace("'","").replace(' ','')
            print testt
            rast = "time" + nowFile
            #print rast
            # this will convert the FIRST time step in your netCDF file to a raster layer
            arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, "lon", "lat", testt, "", daat, "BY_VALUE")
            arcpy.CopyRaster_management(testt, outLoc + rast, "", "", "", "NONE", "NONE", "")
            # Local variables:
            Build_Raster_Pyramids = "true"
            Calculate_Statistics = "true"
            # Process: Add Rasters To Mosaic Dataset
            arcpy.AddRastersToMosaicDataset_management(outLoc + Nommosaico, "Raster Dataset", outLoc + rast, "UPDATE_CELL_SIZES", "NO_BOUNDARY", "NO_OVERVIEWS", "", "0", "1500", "", "", "SUBFOLDERS", "ALLOW_DUPLICATES", Build_Raster_Pyramids, Calculate_Statistics, "NO_THUMBNAILS", "")
            # print dimension_values
time '28/08/2012 12:00:00'
28082012120000
time '28/08/2012 12:00:03'
28082012120003
time '28/08/2012 12:00:06'
28082012120006
time '28/08/2012 12:00:09'
28082012120009
time '28/08/2012 12:00:12'
28082012120012
time '28/08/2012 12:00:15'
28082012120015
time '28/08/2012 12:00:18'
28082012120018
time '28/08/2012 12:00:21'
28082012120021
time '28/08/2012 12:00:24'
28082012120024
time '28/08/2012 12:00:27'
28082012120027
time '28/08/2012 12:00:30'
28082012120030
time '28/08/2012 12:00:33'
28082012120033
time '28/08/2012 12:00:36'
28082012120036
time '28/08/2012 12:00:39'
28082012120039
time '28/08/2012 12:00:42'
28082012120042
time '28/08/2012 12:00:45'
28082012120045
time '28/08/2012 12:00:48'
28082012120048
time '28/08/2012 12:00:51'
28082012120051
time '28/08/2012 12:00:54'
28082012120054
time '28/08/2012 12:00:57'
28082012120057
time '28/08/2012 12:01:00'
28082012120100
time '28/08/2012 12:01:03'
28082012120103
time '28/08/2012 12:01:06'
28082012120106
time '28/08/2012 12:01:09'
28082012120109
time '28/08/2012 12:01:12'
28082012120112
time '28/08/2012 12:01:15'
28082012120115
time '28/08/2012 12:01:18'
28082012120118
time '28/08/2012 12:01:21'
28082012120121
time '28/08/2012 12:01:24'
28082012120124
time '28/08/2012 12:01:27'
28082012120127
time '28/08/2012 12:01:30'
28082012120130
time '28/08/2012 12:01:33'
28082012120133
time '28/08/2012 12:01:36'
28082012120136
Runtime error  Traceback (most recent call last):   File "<string>", line 48, in <module>   File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 11034, in CopyRaster     raise e ExecuteError: ERROR 001143: Background server threw an exception.
Outcomes
